Irishrally
Platinum Member
- Dec 29, 2021
bbk357 , a few questions and thoughts here...
It's long been noted, and mentioned over the years here at the Den, that Shiro lock bars can be easily pushed past the point of initial engagement. That, in and of itself, is not a big deal. My experience, however, is if pushed deeper they stick there. None of mine spring back on their own. Did you grease your knife to lube and perhaps get a bit on the insert or blade tang? Oil there will generally cause lock stick, but I don't know about grease as I use NanoOil in mine.
Is the initial lock-up solid and in the same place as before? Any vertical blade play now? It's possible that your stop pin is out of round and perhaps rotating it could make a difference.
Does your lock bar tension seem the same? Also the detent stiffness? I should think you'd need more lock bar tension, not less, though how that might have changed with disassembly and cleaning doesn't seem to add up.
I think it might be worth it to de-assemble, re-clean, and put back together dry just to see. I've had knives behave differently after a cleaning and doing so got them back to where they should be. Kinda like re-booting mysteriously solves a computer issue
Shiros generally have such tight tolerances that there's little wiggle room for it--heck, they're sometimes hard to just get apart with everything so tightly fit--but you might get better lock-up location if there's any room to scale-shift. Take a look my thread in the Benchmade pages to understand the principal behind this. Even though you haven't described any centering issue, changing the angle between the slabs and the pivot moves the lock bar position too.
Good luck with resolving your issue.
So, if the knife wasn't this way before dis- and re-assembly, you didn't have vertical blade play before, and you rotated the stop pin to no effect, then my guess is there's enough slop in the fits so that blade's lock ramp is a little farther away from the lock bar insert. You need to move the presentation side slab toward the butt to close that distance, i.e. "scale shifting".So when I flip it there is still a little space and the lock bar is not “complete”. But when I grip it at all, slightest amount, the lock bar pushes over and is complete.
When it’s all the way over there is zero blade movement. But it does not stay there. And he’s there is some front and back blade movement when you flip it and the lock bar is in this position:
I would rather it be “complete” so that there is no blade movement, but as you can see in the video it does not stay, it pops back.
No I did not use grease, I barely oiled the bearings with Rem Oil when I took it down. No stop pin issue at all, looks great. Very odd. But it’s hard to tell how to fix this because I have not see many neon hard users out there that people have reported issues with.
These are back in stock…. Any reason why these are now $850 when the one I bought 7 years ago was around $1000? Are these made differently than the other new F95’s that start over $1000? Odd that the price is lower…
It’s tempting to buy it just to compare and see the difference.
Here is the screen shot of the one I bought in 2018:
Ok you’re on to something here!Elmax instead of M390, don’t know if this run has milled cut outs on the inside of the slabs.
That’s about all I see in difference.
I took a screen shot of the description back in 2018 and it specifically says it’s milled to shed weight… and the new one weighs 5.1 and the old one comes in at 4.8.
Still surprised of the price difference but now we know at least part of it..
I have one of the new ones and it does not have the milled cutouts inside the frame, Elmax instead of M390 and the newer version has a different blade profile (just another difference, not a reason the price is lower). Still MRBS with this knife. I’m not sure if the finish is different from the older versions but it’s nice looking and on par with all of my other F95’s.
(old pic posted back in January)
