- Nov 5, 2016
Madness, I say, madness. Prototype blown burner for natural gas powered Atlas Forge.
No more running out of propane in the middle of forging? Yes please
Beautiful. I normaly don't like lapis lazuli etc but I realy like how you've used it on this oneGyuto 240 × 52mm integral
Crushed lapis lazuli inlay
Thanks henegloBeautiful. I normaly don't like lapis lazuli etc but I realy like how you've used it on this one
Why?Beuatiful knives , I like them .You should round little all that sharp edge and corners on ricasso ......
To make it more comfortable to finger ? Look like steel in front of scale has very sharp edge ?Why?
Only comments that I've had from customers were how great they felt in their hands. I don't think the edge is as sharp in person as they appear in the photos.To make it more comfortable to finger ? Look like steel in front of scale has very sharp edge ?
Or, just drill your holes before you taper...Easy way to dril hole in knife with tapered tang ? Make two of themOne with distal taper blade and one with distal taper tang and drill hole in both at once
Yes , but I can drill scale in same way .......you will need something to do about thatOr, just drill your holes before you taper...
Yes , but I can drill scale in same way .......you will need something to do about that![]()
For drilling tapered tangs you build a jig that clamps at the ricasso and supports the tang to drill for the scales.
Do you have a pic of this jig? I've just been measuring the taper and using whatever is laying around to shim under the scale and drill through. That's how this one was done (not finished - still a work in progress!!).
You support blade /jig/ on flats on ricasso and then you use shims on end of scaleDo you have a pic of this jig? I've just been measuring the taper and using whatever is laying around to shim under the scale and drill through. That's how this one was done (not finished - still a work in progress!!).
What a stunner! Great work!!!
This tang is not tapered but this will give you the idea
