That's great news! Thanks for the update, FortyTwoBlades. I can use it. The weeds are growing fast around here, fueled by spring thunderstorms.The Earle Special ought to be on its way to you in tomorrow's outgoing packages, by the way.
Thanks, FortyTwoBlades. If mowing and stacking grass hay for a few goats and a couple of horses works out, we might plant some alfalfa and possibly grain. I've been thinking down the road a bit. I'll let you know if things go well enough to consider your longer and more specialized blades. The Yankee Grass Blade in the NWT catalog you linked did look pretty narrow. It said it was available in lengths up to 32-36 and 34-38. What did those dash numbers or ranges mean? Were they referring to carton assortment ranges of the even inch lengths provided in each carton (32/34/36 and 34/36/38 for the above two dash numbers)? Then there was the wide at heel Dutch Grass blade and the True Taper, which tapered throughout its length. It was truly amazing how many design variations NWT produced and then add in all the curvature, set, and heel options. The number of combinations boggles the mind!Yours was the second-to-last. Someone else got the last one. I doubt you'd want a grain cradle blade for pasture mowing--they take such a huge bite that they're really best used for lawn maintenance when used outside their original intended context. Grass blades tended to sort of max out around ~36" and were a lot narrower when done in those lengths, for the most part. I do have some vintage cradle blades and extra-long grass blades on-hand, they just aren't listed.
The modern Austrian-made blades work okay, but do leave something to be desired in the form department, and their curvature could use a little alteration to put it in an ideal range.
That's a nice looking blade and nice looking work that you've done too, FortyTwoBlades!A blade that a customer sent in for me to do work on. 28" long and only 1lb 3.8oz, which is pretty light for an American blade this size. New England pattern with a nicely proportioned overall build despite its obvious wear.
My Earle Special weed blade tang looks pretty thick too. Is that a typical feature of American pattern weed blades?The thick-tanged weed blade he also sent, by contrast, needed a couple of heats to get it bent to an equal angle.
Ahh--I had not thought of that. Makes sense. Thanks for all the other information too. Thanks for posting it. It's great stuff!From what I can tell, due to the hand-forged (open-die) nature of the blades and the human error in cutting the stock from which the blades themselves were forged, there was variation in the actual length of the blades, and the length ranges denote the approximate lengths you could choose from. That is to say, you would get an assortment of lengths within that range in the carton.<snip>
How long is that biggest one?I had a big bunch of blades to grind and ship out today, and took the opportunity to snap a few photos of how to safely carry blades such that if you trip or fall that you won't slice yourself to ribbons on them. This applies whether carrying just one blade off the snath or several at once. The blades (if multiple) are stacked together with the bottom of one rib sitting in the top of the next. The hand grasps these firmly from the spine side, and the spine at the heel end rests over the interior of the elbow. This faces the edges outward and away from the body such that they would fall away from you if dropped, and so be least likely to seriously injure yourself. If the stack is too wobbly to safely carry securely one-handed, they may be grasped by the spine with one hand near the toe and the other at the heel, but the edges should be kept facing outward and without obstruction from your arms so that if they were to fall, they could fall freely without hitting you in the process.
Needless to say, bare blades should always be transported with the utmost caution, and should be covered and/or stored out of harm's way at the soonest opportunity.
Cool! That thing is massive!28".
I think your post explains why the old (new old stock) NWT Earle Special weed blade that I snagged from you is easily my favorite blade for mowing our fescue-rich lawn, despite its somewhat short length for lawn and grass use. (I expected it to excel at weeding, which it does too.) I also find that the hefty Earle Special eases my mowing effort, because it requires my arms to add little to no down force to the snath to achieve good cutting action; the weight / edge pressure / loading of the blade on the ground alone is usually sufficient. I grow tired of pushing down with each cutting stroke on all my other blades and I think the weight of the Earle Special helps to keep the blade from bouncing when encountering slightly uneven ground too.In the case of the hook-nosed blades you end up with a proportionally small amount of slicing action and a lot of chopping action, while I prefer a heavy emphasis on the slice along the most distal 2/3 of the blade and the chopping clinch delivered only at the most proximal 1/3 at the heel. If you then want it more choppy you just hang it more open, but in general I find that placing heavy emphasis on the slice gives greatest overall satisfaction.
There is one more difference between my Earle Special and all my other blades. The Earle Special appears to be a half-set blade whereas all the others (including the modern Seymour) appear to me to be quarter-set or perhaps they could be considered "zero-set" even! I doubt it's the difference that's making the difference for me but I thought I'd just throw it out there for your feedback, FortyTwoBlades.
