- Sep 5, 2006
The studs are pressed in from one side. Not screwed together I also suspect the blade was bead blasted first then stonewashed second. At least that what I see when I inspect mine.
So they are all like that?
So has there been any news on the 0550 estimated production date?
What are they gonna use now ??This was after the announcement that Vanax would not be used.
I think that after you have it for a while and it gets broken in then it will open much better for you. I thought the same thing when I first got mine and now it is super smooth and opens like lighting. I used if for a couple of months and then took her apart to clean her up and it's been fantastic since then. Just my 2 cents.
Yes. I have two now and just traded off a third. There is some level of press marks an all the studs. If they bother you I can see with a little work with some emery cloth strips you might be able to satin-ize those shiny streaks if you tape off the blade first.
Excuse me, I can't type.
What I meant to write was, I can't close it unless I use two hands. Once it is open, the lock bar gets absolutely stuck, it takes two hands with a lot of force on the bar to get it to disengage.
Overall the fit and finish isn't what I would expect from a $200 knife. But the design is awesome.
-Freq
Try the pencil or Sharpie trick on the tang of the blade; right where it contacts the lockbar. This will help the lockbar from getting stuck so bad.
About six weeks ago, Kershaw announced they would be using CPM-S35VN.
Here's the thread: http://www.bladeforums.com/forums/showthread.php?t=814455
I suggest getting one of those springy things that increase thumb strength for gripping power. They also have those squeezy ball things that release tension. That may also work.Sharpie and pencil does nothing.
Still requires me to use both hands on the lock bar, with a ton of force to disengage.
This is a bummer because I absolutely love the design of this knife otherwise, blemishes and all.
Anyone know what I can expect if I send this back? I mean, if they are a limited run, do they even have the means to fix/replace it?
-Freq
Send it in. KAI customer service is second to none.
Does anyone notice the thumb stud on one side having "skinned" looking places all the way around it? Mine looks like they pushed it through and left the marks on the one side. Never seen that on any knife before. The stone washed blade when looking close looks like it was an excuse to leave some pretty good scratches on the blade's surface to me, also. Nothing like the evenness of say a Sebenza's stone wash blade finish. The lock bar on mine is fine and the blade centering perfect.
Here's the thumb stud you can see the marks on the upper side they go all the way around, are all of them left like that?
Hey RD I'm pretty sure this guy jj sold his ZT for cost. Some people, they just expect a $200 knife should be more like a $400 one. One could only wish that were possible...
and yea some very fine sandpaper and a little know how goes a long way for all us knife nuts.
