I suggest getting one of those springy things that increase thumb strength for gripping power. They also have those squeezy ball things that release tension. That may also work.
It's a man's knife and requires man power to use it.
Seriously, there have been a few other posts with possible solutions.
1) tighten up all the screws
2) you said you tried pencil. But, instead of pencil get real graphite that comes in a tube.
3) read my suggestion and just work the hell out of it to polish up the tang.
4) NO luck with 1-3? Send it in. KAI customer service is second to none.
Hey, Gnarly, etc, I got one!
Good news/bad news. My local pusher/enabler had three last Saturday. The demo was fine, so I just picked an unopened box - should have looked! The knife has a perfect edge - super sharp - and perfect, QC wise. Oops - the closed blade is slightly off-centered... and the action is stiff.I removed the clip, as I do all of my knives, and loosened the pivot and both side screws. I used a needle applicator and some clock oil on the pivot bushings and the lockbar ball. I then retightened the side screws and tightened the pivot until the action was acceptable. It's better, but the blade seems pushed to the G10 side - maybe 40% over; 60% to the lockbar side. Loosening the pivot screw gets it closer to the G10 side.
I like the knife - and it's action is acceptable - opens and closes one-handed, but not a 'flicker', that's for sure. I don't know if it is worth returning it for the slightly off-centered while closed nature or not. It is aggravating. The lockbar overlap is 40% or so - and released by my thumb while ty finger rotates the blade - with no problems. I compared the last few degrees of opening - until lockbar 'drop' with my 0301 - the 0551 is slightly slicker. Mine is #622. Should I leave well enough alone - or send it to the 'spa'? Have others noted a closed blade position determined by pivot screw tightness nature in their example? Thanks!
Stainz
PS One positive note... the store gave me a 'good customer' discount - left enough, with s/t, from the MSRP for a Mex lunch, which my wife wanted after seeing the 'Mexican steel blade' - El Max!!
Hey RD I'm pretty sure this guy jj sold his ZT for cost. Some people, they just expect a $200 knife should be more like a $400 one. One could only wish that were possible...
and yea some very fine sandpaper and a little know how goes a long way for all us knife nuts.
So even if you have two of the exact same knife they could, feel-wise, effectively have two totally different framelocks. I wonder why this isn't more standardized.
All my Sebenzas and my Star-Tac, have the same feel to unlock the bar.
They do vary a bit as to how far the bar is engaged when locked (most are early one is deep), but they are all smooth and easy to unlock, plus they all have bank vault tight lockup. So, it can be done.
There seems to be almost no consistency in the production ti framelock world.Sure, but more relevant to the thread, the consistency seems particularly off on the 055xs...
You did say "almost no consistency in the production ti framelock world. "
Which includes CR's knives.
LOL...stick with robots Jack.
the thickness doesn't cause the bar to stick, it's the angle of it. if you have more Ti touching the side near where your thumb touches the bar what is happening is your downward pressure(to close knife) is forcing even more of that TI bar angle into the blade kinda like a wedge.
sanding it down and making it more perpendicular should remove the "wedging" effect.
not having that problem with any I wouldn't know for sure.
Even if I had the problem I think it would be best to send it in. Wouldn't want to give someone the wrong info.(void the warranty) on how to fix their problem...cause it's their knife.
Josh
There seems to be almost no consistency in the production ti framelock world.You did say "almost no consistency in the production ti framelock world. "
I concede your point, but my initial claim still stands: there is almost no consistency--I didn't say there is never any consistency. Given the vast number of Ti Framelock models available, even if we add all CRK framelocks and maybe the Lochsa too they represent a huge minority insofar as consistent models (perhaps that statistic would actually be otherwise if we discussed actual numbers produced given that the Sebenza is likely the most common titanium framelock in the world. Nonetheless, I unintentionally left "ti framelock world" ambiguous and it may be construed in either fashion. Given that I am the creator of the statement, I now clarify that it refers to the difference between a given model and not relative percentages of ti framelocks produced in the world).
Nonetheless, upon reflection, I should qualify my claim with noting I mean only to include production knives. I just don't have enough experience handling similar models of custom knives to make that statement.
As to the topic at hand, the differences in lockup properties among the 055x seem relatively extreme compared to other ti models, even from the same manufacturer (i.e., 0300). Especially given the relatively small numbers of 055xs produced so far.
If your lock is sticking so bad that prying or extreme force is needed to unlock it then its time to send it in.
When a frame lock sticks and binds prying it is probably the worst thing you can do. It will deform the lock face and make it even more problematic. When this happens its better to press the edge into a board putting pressure on the thumb stud/stop pin which lessens the pressure on the lock bar and allows you to easily release the lock in a safe way.
My 0551 was exactly the same, the lock was galling, lock-up was at 90-100%, and when the galling stopped the lock bar simply was at rest behind the tang, yes, not touching and developed vertical play.
No amount of pencil markings or sharpie will fix a bad lock, if its sticking bad then it needs to be fixed.
