Dan- I was curious as to when you might get around to this new production run. I'm not pressuring you, I'm just very interested. I read your recent nessmuk thread explaining your backlog of knife orders, and don't need a Bushcraft immediately, but would this run come sometime in early 2009? Sooner? Later? Let me know so I can save my pennies and await a 3V bushcraft with striker tip and thick micarta scales.
I emailed Dan about a custom bushcraft and he stated that the new bushcraft run would take place in early 09'. So I am in the same boat, eagerly waiting (and saving).
See the pic I took:Having a Fehrman Peacemaker, I have grown quite fond of 3V. At the same time I'm on the look out for a smaller lighter blade. Can anybody please tell me how long is the blade length of the Bushcraft and what is the typical weight?
See the pic I took:
http://img169.imageshack.us/my.php?image=kostermodifs1ex8.jpg
My palm is about 8cm wide. You can do the maths.
About weight, I have no exact idea I'd say something like 150g.
IMHO-If you think that part of the knife is useless you probably don't really understand it's function.
I certainly do not think it is useless, but....... I am not sure I really understand it's real function either.
What is it ?
Help me out......... seriously...........
The reason for the "useless" part was actually to give a place for the lanyard so that it wasn't under your grip when you had the knife in hand. Clears it nicely.
Also, I can't cut too much of it off....look at your pics...see how the back part of your hand wraps around the spine at the base...and it's lower than where your fingers grab the blade....if I cut the handle shorter, you'll definitely feel it there...will poke into your palm...even worse for guys with large hands.
:thumbup:
Dan
Here's a drawing showing the first production run on top, then the template I am now using for all bushcrafts "in the works" and then on bottom the new design - which I have further modified.
Dan
and now all 3 with the BushMaster on the bottom:
(drawing is to scale proportionally)
As you can see, even with the enlargments on the Bushcraft, the BushMaster is still quite a bit bigger all around.
Dan
The cool thing about the third design is that those the liked the first two won't be affected by the new third one. For example, if the first-run knife fit your hand well....the new one will still fit your hand. But now it will also fit those with wider palms and longer fingers. And if you liked the guard...you'll like having a little more guard.
So, I think overall...I really like where this is headed.
PB Wilson - the striker tip is part looks and part function (aids in penetrating materials). It's not a swedge...totally different. If you look at the tip from the top (spine) not much material has been removed. Just enough to help you get the knife in deeper into whatever it is you're using it for...including opening letters, cutting cardboard, carving wood, digging, drilling holes, cutting leather/skins, skinning, stabbing, and so on.
I call it a striker tip because I respect Busse and don't want to piggyback on their great ideas/designs.
I put it on a bushcraft because I was having trouble doing fine cutting in soft materials...the thickness was destroying the materials...and sticking the knife straight into a material required more force than I wanted. After getting the striker tip, all the above activities were much, much easier.
And as far as I can tell, it does not weaken the tip.
I grind it at the same angle as the scandi grind...so, it's pretty stout.
And I too would like to keep it under $125 for sure....
I am being very, very tempted by the 3/32" CPM D2....I think it may be a "done deal" now....I'll start a poll next week to see what everybody thinks overall...it would make a killer knife. Superb edge-holding and near-stainless.
Dan
