Wow! Great looking plans. I had a few questions I hope some of the more experienced guys can answer, or the builder/designer (that means you blindhogg and polarbearforge)
I see that the revised design has the extra slot for a tool rest attachment right? I looked at the older pics of it and that wasn't there? Or am I just seeing things.
How old are you looking? The initial kit in this thread is different than the current one. The first/older version of the kit I'll be selling didn't have it. It was added afterwards.
Is there enough of a difference to go with the 8" over the 6"?
If you're hollowing grinding, get a different effect with an 8". A larger wheel also works better for larger blades. I don't hollow grind, so hopefully others will chime in on that.
I would imagine the platen attachment holes would also have to be in different places for the 2 different size contact wheels because of the angle of the belt heading back to the 2" contact wheel. I also can't seem to envision how the platen will be attaching to this newer design all in one.
Here is an image of the two platen styles.
The one on the right is the multi platen. The top most hole and the bottom most hole are for the wheels. The middle hole is the pivot hole to rotate the assemble from wheel, to platen, to wheel, to slack belt. The other two holes are for the actual platen attachment.
Also concerning the all in one, will it allow enough room for the "slack belt" option? especially with the smaller 6" wheel?
If I remember correctly from my drawings there is. When I get home(This will be Sunday, I'm out of town) and draw it up again and let you know for sure.
I would LOVE to see a picture of this attachment set up.
Once I'm done with family/personal matters, I'll be taking more pictures, including this setup.
It is a base mount not a face mount.
A base mount may work, but it hasn't been tested or verified. It is designed for a 56c motor frame. You may be able to bolt it to the base, and have the shaft extend through the opening. What frame style is the motor?
I am almost fully on board with only the reservation that the holes that have to be drilled and tapped will be beyond the average diy'er. I have a nice drill press but don't have a countersink bit and worry about accuracy while drilling the necessary holes. I know a directions sheet is being made up but I guess I need reassurance that I would be able to complete this without being a machinist.
I think it's within the realm of a hobby metalworker. I'm a machinist, and did the assembly of my first two prototypes with a drill press. Nothing special or extraordinary about the tooling. If you don't have a countersink, a drill bit will work in a pinch.
To mark the holes, I put the upright in the base, and then clamp a piece of angle iron to keep things perpendicular. I took a cordless drill with a drill bit that just fit inside the holes in the base, and put a small dimple on the edge of the upright through the holes. I took the base off and my holes were already spotted. (Don't worry, I'll be taking pictures of this)
Your cost estimate is right inline with mine. Most of the little stuff, nuts, bolts, taps, etc, I'll tally in the final writeup. I have those in the shop anyway.
Jamie
