- Oct 30, 2002
I only have the chasis completed and no stand, motor, or wheels, but I'll post some pics when I can.
--nathan
--nathan
Received my kit today looks great Jamie good work. I understand that the bottom plate has a top and a bottom is this the top?
I made mine with the grinder to the right and the drive wheel to the left.
How old are you looking? The initial kit in this thread is different than the current one. The first/older version of the kit I'll be selling didn't have it. It was added afterwards.
If you're hollowing grinding, get a different effect with an 8". A larger wheel also works better for larger blades. I don't hollow grind, so hopefully others will chime in on that.
Here is an image of the two platen styles.
The one on the right is the multi platen. The top most hole and the bottom most hole are for the wheels. The middle hole is the pivot hole to rotate the assemble from wheel, to platen, to wheel, to slack belt. The other two holes are for the actual platen attachment.
If I remember correctly from my drawings there is. When I get home(This will be Sunday, I'm out of town) and draw it up again and let you know for sure.
Once I'm done with family/personal matters, I'll be taking more pictures, including this setup.
A base mount may work, but it hasn't been tested or verified. It is designed for a 56c motor frame. You may be able to bolt it to the base, and have the shaft extend through the opening. What frame style is the motor?
I think it's within the realm of a hobby metalworker. I'm a machinist, and did the assembly of my first two prototypes with a drill press. Nothing special or extraordinary about the tooling. If you don't have a countersink, a drill bit will work in a pinch.
To mark the holes, I put the upright in the base, and then clamp a piece of angle iron to keep things perpendicular. I took a cordless drill with a drill bit that just fit inside the holes in the base, and put a small dimple on the edge of the upright through the holes. I took the base off and my holes were already spotted. (Don't worry, I'll be taking pictures of this)
Your cost estimate is right inline with mine. Most of the little stuff, nuts, bolts, taps, etc, I'll tally in the final writeup. I have those in the shop anyway.
Jamie
