So i did some pixel counting and some math and the overall length of the Air Lite came out to be about 8.318 inches. This is almost exactly the same length as Paramilitary 2.
Here's how i came up with that:
1. Took a picture of the image from the DPO site, the blade is 733 pixels long and we already know that it's 89mm:
89mm*X=733pixels
X is the conversion from mm to pixel, and X=8.23596
2. The overall length of the knife is 1740 pixels:
1740pixels/X=211.268mm and when you convert it, it's 8.318"
Do the same for handle length and it came out to be about 4.814". Blade to handle ratio is about 0.728, which is not bad. But not as good as Benchmades which often meet or exceed 0.75. E.g. the Griptilian is 0.747. However, it's better than Paramilitary 2, which has 0.714 ratio.
This is assuming the blade length info is correct and it's between the tip to the very edge of the handle. However, CS's blade length are often not accurate, or are measured differently.
I guess I had too much time off from work...
