I would prefer a good machete over a katana. It's more readily availible and takes far less skill to use.
Machete... you keep on using that word. I do not think it means what you think it means.....
??? Which Machete? Are you talking about a specific product? From a specific company?
Did some one recommend a Katana machete?
A machete is a thin, flexible, long bladed blade. Typically under 3mm in thickness.
They are usually less effective at thrusting, due to their flexibility. Also, if lodged in a target, they can be too flexible to use as a fulcrum to control the target.
You also seem to think that $400 is too expensive for an American made product with impeccable heat treat and warranty, but list a $950+ Chinese made replica of a Japanese sword as on your list of possible choices.
"Best" especially when listing those specific steels, and cheap ar not likely to walk hand in hand into the apocalyptic sunset togethef......zombies or no.....
Post 34 posted a picture of what I referred to as a pricey machete. Post 29 referred to the Super Assassin which I thought looked like a katana machete.
That biggun would be just fine.
As for the question at hand, I would personally prefer a through hardened blade in that scenario. Yes, there are benefits to differential hardening; but there are drawbacks, as well.
The super assassin is probably one of the most efficient cutting swords you will ever see in your life. Made by one of the best cutters in the world. Back to back world champ.
It is about 6 times as expensive as the nicest sword you posted. No where near as thin as a machete. And would cut circles around any sword you can imagine.
Course, if you want the best-est super sword in the world for killing zombies, but you want more traditional fittings, you can always hit Dan Keffler up. His super assassin 2, and a few of his other designs have more traditional in apperance fittings.
Dan Jeffers work is custom made, and in very high demand. He uses cutting edge steels. What most would term super steels. His geometry and heat treat are spot on.
Neither of those cutting tools can be correctly called a machete, but if you really love the term machete, by all means, keep using it.
Based on your original posts, and responses, you should definitely get the 1055 Cold Steel.
But only if you promise to use it for pull ups.
It will be thick enough for your tasks. Though, 1055 is no super steel. And it won't hold an edge as long.
I'm going to machete on into to bed.
Machete you later.
MACHETE......
MACHETE is one of my favorite movies.
Why go Cold Steel? Is it cause the blade would last longer and not break with abuse cause its thicker? Basically want a badass sword that wouldn't break killing zombies.
You're obsessed with skull smashing. The best cut & thrust swords (katanas, sabres, broadswords) can behead a healthy person, let alone a rotting zombie, & can brain thrust, thru the eye or temple.Swords aren't so good. Most are too light to make it through the skull. .
