I believe one of the test versions was 5/16" thick. Is the final value settled?The Khuk is moving off of the whiteboard and onto the schedule.
Casinostocks wants to know how many “blood grooves” you plan on incorporating and he also wants to know if he can get ECAM scales, a “stabby” double edged dagger grind and a hand rubbed satin finish?I'm actually on the fence on this. I'm currently waffling between .275 and .300.
I want to make an authentic Kukri geometry that works like the real thing, not just a kukri shaped object, and the "real thing" is pretty thick. But part of the reason it's so thick is because the materials used and the application dictate it. Our material does not have many of those constraints. Delta 3V is not going to break, our hands are untied and we can achieve geometries that the traditional makers wouldn't dare.
A key design element, that is not intuitively obvious, is the primary grind angle. The OG "original real deal" is quite obtuse and needed to be because of the poor quality historical materials. However, we know from our knife racing, the optimal geometry for chopping wood is in a particular range (that we can reach) and the kukri are typically well over that range. We do not have the design constraints of the original materials and I would not be doing my job if I didn't tweak the angles where Delta 3V really shines in this application. These narrower angles lead to taller grinds which begin to conflict with the geometry, and therefore weight distributions, of the original kukri. My challenge is to tweak the geometries on this historical design a little bit and bring some of the performance characteristics that we have attained to this piece. I think we are looking at a double twisted grind to do this which is going to mean a different kind of manufacturing process than we usually use.
Long story short, I don't know exactly what the final stock thickness will be yet, I'm still working on it...
You asking for a friend, or are you "asking for a friend"?Casinostocks wants to know how many “blood grooves” you plan on incorporating and he also wants to know if he can get ECAM scales, a “stabby” double edged dagger grind and a hand rubbed satin finish?
Ooo, he also want matte Ti fasteners if it isn’t too much trouble.
Casinostocks wants to know how many “blood grooves” you plan on incorporating and he also wants to know if he can get ECAM scales, a “stabby” double edged dagger grindand a hand rubbed satin finish?
It must be able to severe major arteries and the jugular with one slight flick of the wrist.
Thats pretty cool! Can’t wait to see what you come up with. I think The dedication and ingenuity in getting the geometry right is the most exciting part about CPKs!. These narrower angles lead to taller grinds which begin to conflict with the geometry, and therefore weight distributions, of the original kukri. My challenge is to tweak the geometries on this historical design a little bit and bring some of the performance characteristics that we have attained to this piece. I think we are looking at a double twisted grind to do this which is going to mean a different kind of manufacturing process than we usually use.
Ah. Yeah. You're really looking for a K18 then.
Very convenient for quick prep for a shoulder/European mount, too.Ah. Yeah. You're really looking for a K18 then.
Well the blood grooves question was kinda my idea.You asking for a friend, or are you "asking for a friend"?
Damnit, I knew I forgot something!You forgot to add acid wash! (not satin finish). Must be acid washed because I can't have any accidental reflection and possibility of detection. Where I use these tools, the deal is that I must be totally be in stealth mode but the rest of your requests on my behalf is very precise. It must be able to severe major arteries and the jugular with one slight flick of the wrist.
You mean Nathan’s savings account…I guess I know what my savings account is for now
Hamon?Well the blood grooves question was kinda my idea.
I vote for 5 chirra!
