afishhunter
- Oct 21, 2014
The deleted blade has it's own spring.Probably the space left for that third blade in the original pattern?
Did it require room for the kick and room to pivot it perhaps? I'm just stabbing in the dark, I've never owned a stockman pattern.The deleted blade has it's own spring.
I'm still loving my 2018 BF knife, but I've noticed that there is a lot more space at the end of the blade well on this Buck than I've seen on the GEC patterns and a few other traditionals. Is this just the way Buck likes to do it, or is this particular pattern just meant to have more space?
The blades are straight, not crinked, as each has it's own spring. We talked about it during the polling period. Aesthetically, I don't like it. In practice, I don't notice it.
I didn’t follow all of the polling threads, so I may have missed it... but just trying to understand the design.
The blade length on the forum knife is identical to the length on my other Buck 301. This is a Buck 301 with 2 blades, different covers, different steel, and a full flat grind. Other than those differences, it is still a Buck 301, which is what we ordered.I've noticed that there is a lot more space at the end of the blade well
True, but some get the blade closer than others and thus maximize blade length to handle ratio. I’m curious what the reason for the differences could be.If you are referring to the space between the blade tip and the end of the blade well, I cannot think of a single knife of any brand or pattern that lacks that feature.
The well has another 1/8 to 1/4 inch of room for the main clip even with a straight line to extend before getting close to the back spring termination.
Hope you get yours soon!On my desk while waiting for Christmas Dinner, aromas filling the whole place, I picked up a CASE Mini Copperhead and a BUCK 309. Both small knives, the first being what I regard as a 'true' Penknife pattern as it has ONE spring for both blades, CASE also added an extra brass liner to fill the spaces...not what they used to do.. The Buck is almost the same size as the CASE in length, it's a bit slimmer despite having TWO springs but the integral liner/bolster saves width. The CASE has the angled, crinked (bent..) blades showing very tight nesting and yet no rub. The Buck has a little more space in the well as the blades are straight and work from independent springs but open straight out no offset or blade cant. This is the typical Buck arrangement.
I suppose the Forum Knife is the same as it's based on the Stockman frame, however the Forum Knife has FFG not Sabre so this may explain something .
I don't know as tracking ended for mine on 18th it's still somewhere in the 'system' on the way to Europe. Rather annoying as JP and even meako in Aus have theirs..![]()
