- May 29, 2004
So they only took off about half the thickness before sharpening on yours?Approximately .087” on the clip blade. Same as my Buck 301.
Mine will definitely be seeing a trip to the belt sander if it is the same
I got mine in today. It’s dark out now, so I’ll take pictures in the morning.
The good:
The bad:
- Scales are nice and thin, and evenly matched.
- Great transitions from scale to booster.
- Love the slanted bolsters.
- Stamps and etches are all well done.
- It’s so nice to have a traditional with CPM-154 blades.
- Love the shapes of both blades.
- I really like the size and weight of the knife.
- The pull on the sheepsfoot is about a 4, but very crisp. I like it.
All in all, I’m not blown away. Natural covers are luck of the draw, so no biggie there. The spring gaps are more cosmetic than anything, so I’ll grudgingly forgive. We all knew that the pulls on the Buck blades were a concern, and they’re about what we expected. Weak but not dangerously so. But the thickness behind the edges is an unacceptable mistake. Overall, the aesthetics are not good enough to make it a nice safe queen, and the thickness of the grind makes it even less valuable as a user.
- I got unlucky on the covers. Mine are very light, with little contrast. I may try to improve the contrast with potassium permanganate.
- The multiple gaps between the springs and liners are quite bad. Worse than even my worst Case or Queen.
- The thickness behind the edge of both blades runs from about .038” to .040”. That instantly makes the knife a safe queen in my opinion.
- The pull on the clip blade is about a 3, and not very crisp. Not terrible, but in no way impressive.
- The long pulls are very wide and rounded looking. They are perfectly functional, but not aesthetically pleasing from a traditional perspective. Very modern looking, like the Lionsteel Roundhead pulls. But they look out of place on this particular folder.
Sorry, but I’m just not feeling this one.
LOL! Nobody was throwing around the words "unacceptable mistake". the bunch of us pointing out the roundhead edge thickness (me included) was to provide constructive feedback to Mike at CK to improve future runs (which it was), especially when the blade is M390 and takes a bit of time to profile.Mike caught some flack when the first round of Lionsteel Roundheads shipped with thicknesses of something like .028”. This is much thicker than a first gen Roundhead.
If being .04 behind the edge renders a knife un-usable to you than you should probably only carry Spydercos in whatever super steel you fancy.
It looks like the scale pin might be a tad long causing the gap?Here are a few pics. The elk on mine is a bit lackluster, but some potassium permanganate will likely improve the contrast greatly.
Here are a couple pics of the spring gaps. The clip blade end has one extremely large gap. Big enough to stick two sheets of copy paper through. The blade has no lateral play, so it is unlikely to benefit from hammering the pin and re-peening.
The sheepsfoot end has a couple of gaps, but not nearly as large as the clip side. The sheepsfoot does have quite a bit of lateral blade play, so re-peening may help.
I'll be away this coming weekend, but perhaps I'll get to work on this knife next week, and see if I can fix the sheepsfoot blade play and gap, and make those elk covers stand out a bit more. Both are relatively quick and easy jobs.
