I haven't uttered a cross word since I've been on this forum but here goes. You'd better live up to your signature calling me stupid.One of the reasons I quit buying Spyderco was too thick grinds. He won't find much joy there. Thick grinds are also a pet peeve of mine. Even when I reprofile one to my standard 10dps, the thick shoulders tend to wedge where a thin blade slices. I dislike scandi grinds for that reason. On a folding knife, which by definition is a light duty knife, thick grinds are stupid. Unless you offer a lifetime warrantee against stupidity ... then it's the user that's stupid.![]()
Others are entitled to opinions which may disagree to yours. Queen went under because the traditional community disagreed with you.For those that are complaining about the blade edge grind, grasp the handle of your knife with the blade spine up and place the cutting edge on the palm of your hand. Now, give the knife a yank. Are you bleeding? If so, you've got a good working edge.
Got a gap? Quit complaining. You can use that gap to see through for guidance while cutting with your knife.
Honest to God folks. At least wait until you have your knife in hand before complaining about it.
@skblades - Thanks for your efforts and time.
Here are a few pics. The elk on mine is a bit lackluster, but some potassium permanganate will likely improve the contrast greatly.
Here are a couple pics of the spring gaps. The clip blade end has one extremely large gap. Big enough to stick two sheets of copy paper through. The blade has no lateral play, so it is unlikely to benefit from hammering the pin and re-peening.
The sheepsfoot end has a couple of gaps, but not nearly as large as the clip side. The sheepsfoot does have quite a bit of lateral blade play, so re-peening may help.
I'll be away this coming weekend, but perhaps I'll get to work on this knife next week, and see if I can fix the sheepsfoot blade play and gap, and make those elk covers stand out a bit more. Both are relatively quick and easy jobs.
Lol, time to break out the microscopes.Seems that owning and using calipers and magnifying glasses can reduce perceived enjoyment of ownership of pocket knives.
It looks like the scale pin might be a tad long causing the gap?
Let's keep our heads, after all this could have just been a dud. Let's have patience and see what the rest turn out like?
The GAPBuzzbait you could always send it back to Buck for warranty service. The gap does look pretty bad on that one end.
I tried that once. Hard to twist my arm back there and my back was sore for days. That's one test I'll pass on.But what I'm most concerned about, is how it handles spine whacks.
