Thanks Jack! I hope he earns that stag!
Good morning Guardians! I am a disciple, but not yet a convert. I would love it if those of you who have used a variety of straight-edged blades (lambfoot, sheepfoot, coping, Wharncliffe) would lay out for me the differences, strengths and weaknesses of using the various blades, with emphasis on the lambfoot.
For my typical usage of a straight-edge, I would put the sheepfoot first (strength & precision), the coping second (less strong, but just as precise), and third the Wharncliffe (fragile tip and less precision because of its usual length). I impatiently await your thoughts!
I find the lambsfoot a perfect compromise between the strength of a sheepfoot, and the delicate tip of a wharncliffe. The knives are usually very pocket friendly too. The spine doesn't rise too high above the frame.Most of us like and use many blade shapes, for versatility though, I prefer the Lambsfoot above all others. In comparison to the mighty Sheepsfoot, I think it offers greater precision, allowing the user to see precisely where the tip is being placed, which isn't always possible with a Sheepsfoot, while sacrificing little in strength. I also find the Lambsfoot more precise than the Coping blade, more versatile and easier to use, and also stronger. As for the Wharncliffe, I think it is even more precise, again because it is easier to see exactly where the point is, I think it offers greater control, and considerably more strength. I'm biased, but I think the Lambsfoot is also the most aesthetically pleasing
Now with that two-blade in mind, do you ever see the lambfoot as a shorter secondary, like the sheepfoot usually is found?
Ha! Good one, Jack!The Lambsfoot is never secondary Jeff!
Josh, your little fella sure reminds me of my grandson Samuel.View attachment 945743
I forgot to take pictures at the Farmers’ Market (it was very busy and we had all Five kiddos), but here is my lambsfoot with my youngest son!
Good on you, Jack! The lambsfoot seems like a GREAT first knife. It inspires one to use a knife the way it's meant to be used. What a perfect companion on his adventures.Awww! Great pic Joshua! I recently gave my mate's lad this one, his first knife
He was admiring my wee staggy yesterday, so I told him that if he behaves himself he might get one for his birthday next year
Well, they share something else in common, being named OT names: my boy’s Ezra.Josh, your little fella sure reminds me of my grandson Samuel.
All right then as my Dad would have said quote " he has the makings of a good man"Well, they share something else in common, being named OT names: my boy’s Ezra.
Glad you have the where with all, to describe why you like the LF. I discovered this style of knife, 3 or 4 months ago, it is one of the best everyday users I have come across. As I've said before, I could have saved a lot of money, had I found the LF earlier.This has been my experience as well. I find the blade shape to be well suited to most of my every day tasks. Need to break down a bunch of cardboard? No problem, it happily takes a beating. Need to open a clamshell package? No problem, the tip and angle of the nose is perfect. Cut through rubber hose? Yup. Slice up a rack of ribs? Yup. Cut out a pattern from a piece of paper? Yup, that sharp tip helps there, too. It is by far my my most used blade for non-carving tasks. But, if I could ever find a whittling knife with a small lambsfoot instead of a coping blade, I think it'd be superior for certain types of carving detail work as well.
If I'm being honest, it's not my favorite for food prep. I like some belly for that, but I've sliced plenty of salami and cheese on hikes when the lambsfoot was what was in my pocket and it worked just fine.
To sum it up: it's comfortable in the pocket, it's comfortable in hand, and it's just so dang versatile in use. No wonder it's usually in my pocket.
Ha! Good one, Jack!
I was just thinking about how many whittler pattern knives have a secondary coping blade, and I sure would like to see one with a small lambsfoot instead. The tapered blade and angled tip would allow me to get into tighter spaces.
Echo has taken to the lambsfoot, too!
Morning Guardians. Hope you all have a nice Sunday in the works.
Good job! I'm finding I have more success with my Spyderco ceramic flat stones med/fine than my dmt diamond flats.
I then finish with white then green compound on a leather strop.
I was well pleased with the new Guardian, all I had to do was strop, and it was good to go.Thanks, the straight-edged blades, properly ground, are not usually much of a challenge I've found the same Dave. My '18 really didn't take much time at all, and I actually just dry-stropped it afterwards
