SpySmasher
Lead Guitar
- Sep 1, 2016
That's the entire history of Australian colonialism!Maybe manufacturers just sent their bad batches to Australia?![]()
Ba-dum-tish.
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
He mentioned it several times in the comment section.May have missed it, but he never mentioned ease of sharpening. That would give more information to go by too.
Respect to them for this response. It's exactly what it should have been.
Here's to hoping that it was just a very small bad batch. It would be unfortunate if a lot of these turned up in the wild, especially if not many people are aware. I own a couple steel will knives and I have a carbon fiber modus on pre-order from October. I'm also interested in their intrique lineup, and their ant-lock. This whole thing is far from over, but at least they are taking steps in the right direction.
I've not had any budget knives from masirin but sofar they are nice for the cost. am2 and am3. viper has to be the worst I've seen and heard from feedbackMaserin quality is below all others in Maniago, Italy:
1. LionSteel
2. Fox
3. Viper
4. Maserin
I do have a Maserin Bulldog flipper (N690) and the quality is just okay. There’s a Maserin AM3 flipper with M390 for just $140.
I’ve had a Steel Will Cutjack Mini M390 made in Italy since July 2017. No issues at all but it’s just regular cutting. I don’t know if it’s made by Viper or Maserin. The quality is good.
the cutjack is made by masirin per Peters conversion between him and steel will. and everyone has nothing but high praises for it. took apart my am2 and its fairly nice. though it is heavier than id like. the $130 I paid for it is fine, I'd buy another too, but I think I'll get a cf /m390 steelwill instead.
Okay.. so preliminary results are not looking good. I was hoping this was an isolated issue.
I tested the SAK and got 67 cuts before it would no longer easily slice paper. This is higher than the results he got by about 76% (or about 29 cuts), but I kind of expected this, bearing in mind I was using a lansky edge at 20dps, which he would probably refer to as “unleashed” on his testing.
The steel will modus under the same conditions went 89 cuts before it would not slice paper reliably. And yes, I checked for a burr.
Looking at the edge under a machinist’s loupe, it looks as though the edge has microchipped like crazy or rolled very slightly. I’m going to try some Spyderco k390 to see what numbers I get.
58 HRC isn't low for M390. 58-62 is about the norm for M390.
Rockwell C hardness scale is not a linear scale, rather it is logarithmic.
This means that the difference in hardness between 61 and 62 is greater than the difference in hardness between 60 and 61. As you go up each point on the scale the difference between each point becomes greater.
...I’m going to try some Spyderco k390 to see what numbers I get.
Just finished, got 221 cuts with a Spyderco k390 urban. Same edge treatment as the others which leads me to believe the heat treat isn’t great on the modus..
