Is that something he's planning on doing, or just that you're hoping for? I haven't seen anything on his blog.
I did get one of these:
Made in China, rebranded under various names (mine is "Naithawk" or something like that). It's alright, although (keeping the thread on topic), at $40 it's a bit embarrassingly expensive for what you get (some charge much more). It's fairly impressive considering the machining that went in to the tiny one-piece body. The button isn't as impressive, having 2 tiny springs that are extremely easy to lose inside, and requires disassembly to switch blades. However, it works just fine and I can stab it into wood as hard as I feel safe doing with such a thin blade, and the lock doesn't budge until you press it to retract. The main flaw in actual use that I'm finding is that things are so tight in there that even a small bit of something that gets inside will interfere with the action. I tried powdered graphite as a lube instead of oil and it's much better since the graphite doesn't let pocket dust/fluff/dirt stick inside like oil does. Requires Olfa brand blades because of the type of hole, can't use Xacto.
