- Dec 2, 1999
Iam a sick manIf I'm not mistaken Bruce, the reason that folks say you need to triple quench 52100 is because they're not soaking it long enough to get all of the carbides in solution. If you quench three times without any real soak time you stand a better chance of getting the most out of the steel. If you can, put it in the kiln and soak at temp (I forget how long, ask Kevin or Mete) you can quench just once. Of course, you mentioned only heating the blade, so You may not be able to get your proper soak at temp.
You sure pick easy projects don't you?
-d
One good soak should be enough.
I use an Even Heat oven for HT and plan to make a temporary door with a slot for the blade. Only the blade will get hot hopefully. I should reinforce the webbed section with plate steel and maybe foil wrap it and the handle just to be sure.
