- Oct 11, 2010
Are there any practical swords out there? Post suggestions, links, pictures. Go crazy.
I didn't mean for combat i meant for the bush, like the condor bush cutlass.
Triton, you are correct, but i would like a sword as a show piece and i don't get anything i cant use.
I'm suprised anyone hasn't said it yet
It's okay, I don't like the handle, it's too small and is akward. It's long and thin, very flexable, okay for tall grasses, but I'd rather have a 23" latin machete, or other proven designs.
The Scrapizashi is very fast in hand and clears brush almost as good as a machete and it will out chop a machete in hard wood chopping any day. A machete's soft steel will lose its edge if you are really putting it through its paces with hard wood. The Scrapizashi on the other hand will still shave when you're done then laugh and ask for more
I think perhaps a higher quality machete is needed for comparison. I haven't had to resharpen any of my personal pieces in the field, and depending on the pattern choice they should do quite well against hardwoods. While your Scrapizashi is a very fine piece of work and does quite well for you, a blanket statement like that mistakenly implies that all machetes are created equal. I bet a Martindale heavy bolo, for instance, would fair quite well in a chop-off.
Thin stock+ wide blade + high end steel = chopping machine.
This sword is practical for us old timers. And when they say it's battle ready, they're not joking. After a recent tornado I abused the heck out of it cutting branches off of fallen tree limbs. Came from Cold Steel razor sharp, and holds an edge very well. Only problem is that in Virginia, I can only use it on my own property. This sword is VERY well made, and has the cool factor, too...
http://www.trueswords.com/cold-steel-battle-ready-sword-cane-heavy-duty-p-3421.html
wrong tool, wrong job
