- Mar 6, 2013
Did Stan throw up YouTube video by chance? Gavko put one up on you tube and he was literally giddy just like any other regular knife nut. LolAdd Stan Wilson to that list![]()
The ZDP version has to be pretty damn good to get a grind that thin. Spyderco's ZDP is at 64 and my only experience. I'm curious too about ZDP at 67. E.G. is it chippy or not in the least bit?
...When I visited Stan Wilson for the first time, I asked him what he was carrying in his pocket. I snapped these pics of his personal carry KOU (3" folder)...
http://instagram.com/p/lGOMURy2lX/
Great thread! It's been a good read. Rockstead has always been a curiosity for me. But hearing about usage, maintenance, admiration, I'm very interested to try for myself.
If someone has experience with the 2 types of metal offered, please enlighten me.
Subscribed!
Good information! Interesting the graph calls these steels stainless. How is the corrosion resistance of YXR7? Same as zdp? Is a coated blade worth getting?
I have 2 Rocky's in YXR7, and I've never tried their ZDP-189. YXR7 is a carbon steel with high hardness and toughness, while ZDP has a higher hardness with less toughness.
Rockstead demonstrates that YXR7 has greater impact toughness than ZDP-189, but on the other hand, ZDP has better wear resistance than YXR7. ZDP will chip while YXR7 will roll when the edge is exposed to impact.
Personally, I have no desire to own their ZDP knives since they are too brittle for my uses. YXR7 seems like the perfect steel for a "hard use Rockstead". If you cut soft materials like rope, clean cardboard, fabric, etc then get ZDP-189. If you cut dirty cardboard, carve wood, or (lightly) chop things, get YXR7.
Well I stand corrected. Thank you for this! I was considering a Higo in ZDP now I'm thinking I need the YXR7 instead for the kind of use I'm accustomed to.
Being in the PNW where its always wet, would this type of steel pose any concerns or is it just simple maintenance of cleaning, drying and lubing after such use?
I know there are also different variations of the models in YXR7. Some feature a DLC coating on the entire blade, which makes for a very interesting "smokey mirror" effect unlike anything I've ever seen before. However, I've seen some that only have the DLC coating on the flats and not the bevel, giving the bevel a typical mirror finish.
Their reasoning is that the mirror finish helps repel corrosion and full-DLC isn't necessary. I prefer the fully coated versions![]()
Well, that brings me back to this:
The DLC coating will protect the blade, but it should still be wiped down with something like tuff-glide. Apparently the DLC coating has "dimples" according to Rockstead, and make the blade susceptible to corrosion. I'd imagine the partially coated YXR7 blades require slightly more maintenance.
I'm in a similar boat as you bladeninja.Gosh. Decisions between the two steels...I'm going to have to do more research before I commit. Either way, I know I'm going to be very pleased with my purchase. I just want to be absolutely certain of the best steel for my use. This one will go to the grave with me. Hey...didn't you already say that BB?
Hmm. Choices... Higo or Hizen. I see there's option for a polished DLC on YXR7. Anyone wants to show off their polished DLC? Googling it is just not the same.
In honor of our Veterans.
