How do the inlays hold up?Here is another
I’ve only had mine a few weeks but that Stingray skin is really inlayed well and have never heard of any owners saying otherwiseHow do the inlays hold up?
Stingray skin will show wear, the black coating wears off the nodules but the nodules themselves are quite durable...they're basically tiny pearls.How do the inlays hold up?
Never seen nor heard the wear you speak of on Rockstead Stingray inlays yours is the first .Stingray skin will show wear, the black coating wears off the nodules but the nodules themselves are quite durable...they're basically tiny pearls.
Yes, as a craftsman I am VERY familiar with the quirks of dyed stingray....Rockstead doesn't have some magical version. If you look at the cut edges you can clearly see the white interior of the calcium nodules, and the layer of black dye on the surface. Obviously, this won't affect safe-queens that are only used for picturesNever seen nor heard the wear you speak of on Rockstead Stingray inlays yours in the first .
Have you seen this or is this just speculation on your part ? Have you owned one and if so please provide some pictures of the wear you speak of . Like Micarta , DLC or color by number anodizing by craftsman ? I imagine after time and depending on use they all show some type of wear though.
Never seen any issues or wear on Stingray inlays on rocksteads . I imagine it all depends on the craftsman's application and curing process of the stingray .Yes, as a craftsman I am VERY familiar with the quirks of dyed stingray. If you look at the cut edges you can clearly see the white interior of the calcium nodules, and the layer of black dye on the surface.
That would be false, all stingray is prepared the same way...it's ALL dyed. That dye WILL wear off with use, there's no way around it.Never seen any issues or wear on Stingray inlays on rocksteads . I imagine it all depends on the craftsman's application and curing process of the stingray .
I’m sure there are many variables just like blade steel and each individual. HRC .
Never “ prepared” Stingray’” so I’ll have to take your word on it. But then again I’ve never seen worn out Stingray inlays on Rocksteads. Doesn’t mean it can’t happen just never saw it except for a loose piece you’ve provided.That would be false, all stingray is prepared the same way...it's ALL dyed. That dye WILL wear off with use, there's no way around it.
Very nice love the natural wear patina .The dye will eventually wear from the pearls.
Heres a 6 year old EDC SHIN.
But even on my old stingray watch straps they eventually wear.
