TUTORIAL POST #9
Setting the closed position.
This, in my opinion is the most complicated of the three positions to set. your goal here is to get your blade closed to a point where the tip is hidden below the handle scales and the backspring is flush.
I have found that creating one large radius on this surface is the best method to achieve a solid closed position. There are lots of opportunities for mistakes here. the first mistake you might make is to extend your radius too far towards the half stop position. You need to make sure that your point of contact nearest the half stop does not extend into area you have relieved from the face of the spring. hopefully this picture makes that more clear. In the picture this point just hits edge of the spring. If any more of the spring was relieved this point would overshoot the end of the spring. If you identify this before you start removing material from the kick side you can correct it by making a small mark where the spring lines up with the half stop and only grinding your radius to this point. If you try this you will have a tiny flat spot at the end of your radius. This is not a big deal and should not affect functionality.
All adjustment here is made by removing material from the kick portion of the blade as pictured above. NOTE: you can use a RFI to get close but the final fit will need to be done by assembly and testing. I have found that even when simulating spring tension the tip will usually sit slightly higher when assembled in the closed position.
Essentially you are adjusting 2 contact points. Each point affects one area the most but each one affects the other a bit. To get this dialed in it requires a bit of back and forth. The two contact points for this tutorial will be the
TIP SIDE (this is the contact point nearest the tip of the blade) and the
REAR SIDE (this is the contact point nearest the half stop position). Hopefully this makes sense.
Removing material from the tip side will lower the tip further into the handle when closed. I find that all material removal for this step is best done with a small wheel attachment. A Dremel should also work. Remove material from the tip side while retaining a radius shape until the tip is just sticking up from the handle.
Removing material from the rear side will lower the spring into the handles. you will want to remove material until the spring is about 5 thousandths proud of the scales. Use an RFI for this if its available to you. If not just assemble, test and repeat.
Once you are relatively happy with both positions move back and forth between removing material from both positions until your spring is flush and your tip is hidden. Be patient here and remove small amounts of steel at a time. Watch your heat. I like to use a 240g or 400g belt.
Once completed you should be left with something like this. I hope this step is clear. If anyone needs clarification let me know. This is the most difficult step to put into words. If you can get to here the remaining steps should be no problem.
