- Jun 4, 2010
^Yes. See the article I linked earlier on benefits of CBN. Again, its benefits for grinding applications are mainly:
Also BTW, note this interesting blurb at the end of the article, kinda' caught my attention with regard to future applications of cbn:
- Withstands heat, especially during high-speed applications
- Does not cause grit that can dull bits
- Stays sharp and cool because it does not react with steel
Now back to our world: I think for manual sharpening application, the first and third bullets above are mostly irrelevant. However the second point could be germane to DM's question, if Spyderco manufactures the CBN right and its well embedded on the plate, in theory during the process of sharpening it should not shed as much grit onto the steel being sharpened. Obviously the proof will be in the pudding there, it's never just a theoretical question of how CBN "should" do X or Y differently from diamonds, it's always in an actual implementation in a real stone that somebody makes. Because as we've all seen, you can't just generalize about how 'diamonds' work in all cases, you always have to look at a particular diamond plate: DMT, Atoma, Ultrasharp, somebody else, they have similarities, but all can work quite differently, wear out faster, produce a different finish, etc.
Sounds like I'd have to get a Cbn plate and compare. Am not sold on its superiority to diamond at hand speed or slow mechanical.
It isn't used much in lapidary work, but again that might be due to mineral shape or cost as opposed to durability.
