I’ve always referred to plated diamond as..... diamond plates. Same with plated cbn.... cbn plates. I think it is you who referred to them as stones.it's easy
electroplated sharpening blank is not stone
and can not be, even if manufacturer say so
I will say I find glass, vitreous, to be a very interesting bond for diamond and CBN, although I would really like to see how well it bonds to either of these materials with an SEM before going too far with it. How much experience do you have using these different bonds? They all have their strengths and weaknesses. Which is best depends on the application and desired results, so, there is no one best bond.
Since there is no stone in most of our knife sharpening stones I think calling any of them stones is incorrect, so we might as well call any of them that does the intended purpose of stones, stones.
HeavyHanded
Did I somehow miss your commentary on the Spyderco CBNstone platehonesharpening device?
Its coming hopefully next week, had a merry time of it with USPS...
Quick review here, I plan on doing some more with it but these are initial impressions.
The plate blank itself is very flat, abrasive laydown is very uniform. There are some very small manufacturing dimples on the 400 grit side but they are too small to effect performance in any way. Overall the quality is there.
The 400 grit side cuts a touch more aggressive than a coarse DMT in terms of speed and scratch pattern. Feedback is a little better.The 800 grit side has very good feedback. Scratch pattern is slightly less refined than DMT Fine. Common to both sides of the CbN is good feedback and ability to shave off the burr at a much lower angle than the DMTs.
The 800 is a very good utility edge. If you like more of a push cutter you'll def want to follow with compound, film, or a finer plate.
To start I used both sides to true and sharpen a 1" wood chisel, you could feel the loose bits being removed pretty easily on the 800 side. Rinsed it with water as I went to remove the debris. I have no idea how much more break-in will be achieved with more grind time, possibly folks familiar with the CbN rods for the Sharpmaker will have more insight. It didn't feel like it was going to be a quick process following the initial break in.
I tuned up several 8" Chef's knives that were heavily worn, the 400 grit side is really not rough enough for that sort of work and I found myself wishing I'd had my Crystalon. Once I got the bevel reset it worked well. The ability to remove the burr at lower angle and with fewer passes apparent even on budget steel.
To me, that is the defining characteristic of this plate/media, nicer feedback and more efficient stock removal than a comparable diamond plate. Despite this, grind speed wasn't noticeably better than DMT on 10v or budget steel, but the final edge cleanup was easier.
Cleaned up like new with baking soda and a scouring pad. Overall a good plate, comparable to a duosharp C/F in terms of where it would fit in a progression.
I have a wheel that is diamond bonded in a very India stone-esque material. I have no idea why nobody makes these in a bench stone, or in various grits. The wheel is about a 4-600 finish.
Generally in my experience, proper terminology is that a flat electroplated sharpening device is called a "plate;" a natural sharpening device mined from the ground is called a "stone;" and a man-made flat sharpening device with either full abrasive content or a layer of abrasive in a vitrified, resin or even metal binder is called a "hone."
But as far as I'm concerned, this is one of those things where there's no reason to nitpick. We all understand what is meant even by use of the "improper" terminology.
This is made for a low rpm wet wheel, the composition is very similar to vitreous India stone, but with addition of diamond.That is called a vitreous bond. They are generally mostly used in powered grinding because they resist the high heat that can be generated during that process well. That's not really necessary for a hone that's used manually, a resin bond does just fine for that purpose.
