this... Bf + strider = facepalm ImoThe answer to this questing varies heavily on the forum on which it is posted. There are many members of BFC that dislike the owners of SKI and it tends to permeate every single answer.
To be perfectly honest I have never understood why people buy factory knives in this price range. If you're ready to drop several hundred bucks on a knife why don't you just go with a custom? The fit and finish will be better and you can have it customized to your specs.
I prefer the lighter weight, stronger detent, and neato, integral G10 handle/backspacer of Striders.
Price should also be considered.
Strider now carbidizes their like face as of a few months ago. Also, knife maintenance is end-user responsibility. My XMs that I have owned all needed adjustment and they weren't even coated blades. When you buy a coated blade built to high tolerances, once the knife is broken in, of course some side to side play will develop. Pop the loctite and tighten the pivot. Problem solved. Again, my XMs developed the same play after use.Not the same models, but here's my take on the two brands.
I held out for the longest time on a Strider for moral reasons, but after awhile I was too drawn into their design and had to own one. The SnG z-wear with new lock geometry I picked up was great at first, although the f&f wasn't there, it was still a solid knife. But, within a week of using it, the lock became super sticky, and developed a good amount of side to side play. Some pencil lead on the lockface fixed the stickiness, and I'm sure I could have tightened the pivot to remove the play, but in my opinion, a knife in this price range shouldn't take this much work to get it right. On the other hand the handle shape was surprisingly ergonomic in a lot of different grips, super light for the size, yet still felt like it could take abuse.
My XM-18 however has all the benefits the SnG has (except for weight), with none of its issues. I'd say the main drawback, compared to the SnG, would be the added weight, and the secondary market prices. Also they both have different ergos and for me the SnG felt slightly better in hand. If the XMs were readily available to everyone at first responder pricing, it would be no question which knife I'd want first. In the end, I think both knives have a place in the community and it's worth it for any knife enthusiast to handle and use each knife at least once to form their own opinions about them.
The Strider folder design stands alone. Not many mention this fact. I don't think a folder can be made any stronger.
Really? How does it stand alone, exactly?
There are lots of tests out there that show how framelocks are not the strongest lock out there.
Matter of fact, since the Hinderer has a stouter grind, AND a titanium liner under the G10, AND has the thumbstud contacting both sides of the frame, I'd guess that they are in fact stronger than a Strider, not to mention other knives with the same attributes.
Arguing absolute knife strength is useless. No data. I have never seen any pictures of a good folder handle failing.
