I just wanted to update everyone on some new information I got about the K02 and K03 knife sharpener,I ordered a second set of double filet clamps and 2 scissor attachments from George at STATES and that is where I discovered a the problem with the new 20mm fixing unit's that came with mine,since then I also ordered another set of Conical clamps and reinforced spring's because I want to have a second set around because I like to use them a lot and want a back set and this is when George informed me with new information everyone should know.
What has happened is when Tsprof changed the Crossbar design for the new 20mm fixing unit's they also had to use longer nut's is what Tsprof is calling them,the problem is from what I understand all of the clamps George got in his last order to sell as accessories only had the 20mm fixing unit's and the other problem is the 20mm fixing unit's came with nut's for the 10mm fixing unit's witch are shorter then the nut's for the 20mm fixing unit's,I will be posting picture so this will make more sense and also explain it more.
I have contacted Paul by phone and talked to him about this problem and he told me he will be sending out some nut's to George and also another thing to be aware of is George told me when Tsprof has sent replacement fixing unit's they only sending the fixing unit no 4x6mm screws or nut's and if you have been following this thread you know I have just ordered the 20mm Crossbar and I got replacement fixing unit's sent to me and I was not aware of the shorter not mix up problem when I got Paul to send me my new fixing unit's and Crossbar,when I talked to Paul on the phone he said if my for me to figure out how many nut's I would need in total to replace the shorter nut's to the longer nut's and email him that information and he said if my order was nut sent with the longer nut's he would send me the amount I requested,I was told by Sergeytechman in an email my order did not ship with the any nut's and they are sending me out the longer not with in a few days.
Ok I will now explain what the nut exactly is that I'm talking about as I'm sure many of you are thinking there is no nut on the fixing unit,the nut is the part that has the knurled knob on it and the threaded shaft that you screw into the fixing unit to hold the fixing to the crossbar,if you look at the picture on the left there is a scissor attachment with a 20mm fixing unit and nut and on the right side there is a conical clamp with a 10mm fixing and nut beside it.
The problem is the both nut's are the same in length the nut for the 20mm fixing unit should be longer because from what George has told me a customer called him and made aware of this problem and told him that the thread shaft on the nut was not long enough to engage and thread into the fixing unit.How much longer are the new nut I do not know but I will update this thread when I get my new Crossbar and nut',the length of thread shaft on the 10mm nut's is 18mm.
