- Jan 4, 2018
Can’t wait for my Massdrop x Ferrim Forge Mordax so I made a pearl colored lanyard to match my TR-3’s button instead.
I found one.Does anyone know of a nice pearl white lanyard bead? i have a Protech with a pearl inlay button and I’d love to do a matching bead.
I don't know why the Para 3 wouldn't be a lanyard knife, but I do think you're right about about different knots. Not sure what you've got there--maybe snake knots, the last three not well cinched up together. That space after that first one is good to let the lanyard hang down and I do that on some of mine for that purpose.What kind of lanyards are you guys running on your Para 3s? I tried one on mine and I think it looks like dogshit. Maybe it needs thinner cord? Different knot style? Or maybe the Para 3's just not a lanyard knife? Maybe I'll try one going around the tube rather than through it.
Always have a hard time keeping 550 tight.Not sure what you've got there--maybe snake knots, the last three not well cinched up together.
550 can be tough, especially if the cord jacket is stiff. I always try to get cord that's softer and has some slack to it. Hard to anticipate when you're buying online, but I've learned some who has better cord and whose generally sucks.Always have a hard time keeping 550 tight.
The external sheath of paracord can be either polyester or nylon and the internal strands can be either poly or nylon as well, so you can get paracord in four different material combinations. I’ve used poly sheath/nylon strand cord and nylon/nylon. I prefer the latter. It seems to be more pliable and to tie better into tight knots. Have you found any differences in the handling characteristics in cords made of the different component material combinations?550 can be tough, especially if the cord jacket is stiff. I always try to get cord that's softer and has some slack to it. Hard to anticipate when you're buying online, but I've learned some who has better cord and whose generally sucks. Something I've learned after mucking up a lot of knots is to give myself lots of cord to work with and not worry about throwing a foot away here and there. Also, to tighten knots, go a little at a time, back and forth, and don't try to cinch up hard with each pull. With a snake knot, say, pull a little on one free end with your opposite thumb against the knot, then switch and take it up bit by bit.
I hadn't thought of the differences in cord being due to different materials. I'll have to go through what I have--probably 15 or so hanks--and see if there are any marked labels in what bags I have left. Judging from what you've said, Stumpy, I'm guessing that the softer, more pliable cord I favor is likely nylon/nylon which is much easier to form and holds shape better.The external sheath of paracord can be either polyester or nylon and the internal strands can be either poly or nylon as well, so you can get paracord in four different material combinations. I’ve used poly sheath/nylon strand cord and nylon/nylon. I prefer the latter. It seems to be more pliable and to tie better into tight knots. Have you found any differences in the handling characteristics in cords made of the different component material combinations?
