J
Just Tom.
Okay, as a starter
One that you're familiar with
Very snappy, solid half stop. Doesn't feel cheap with the exception of the metal key clip. The liner lock looks to be made of cheap metal but does it's job. There is a slight up and down blade play when open but I find this to be common with a slip joint liner lock. Definitely needs sharpening
variation with can opener
Electrian
Solid feeling knife. Walk and talk is fantastic with the exception of the aul. That thing will break my nail if I don't be careful. The aul is super sharp but all other edges need touch up.
Wire strippers do catch my nails so I think it will do the job but I'm not an electrician
Got the knife because it looks cool.
100-NH-5 Stovka (model name)
It looks cheap because of the color, but the walk and talk/fit and finish is Victorinox grade with the exception of the can opener. I tried to take a close up shot but you can see it is very roughly ground. I think it will do its job but might pose a little struggle. No wiggles, snaps clean. Also need sharpening.
So far so good. More to come
Want to see if I can put an okay edge on these. Given most of these are either 440A or 420 steel, I don't see it holding an edge for hard use, but 'should' sharpen easily.
