The mini bikes arrived yesterday and I got them assembled , after a few hiccups both run great now.
I also got the racks in today and mounted mine.
A few things to note.
1st - they vibrate a decent amount so gloves or some more cushy grips are a good idea.
2nd - the manual makes no mention of it, but don't think you're going to just gas it up a little for a quick test run.
Theres a device ( possibly a float of sorts , not sure ) that prevents you from running the sludge and such that settles in the bottom of the tank.
You've gotta have a decent amount of gas in the tank.
3 - mine was missing the front axle nut and screw plug for the carb bowl, cheap and easy enough to get at the local hardware.
4 - forget about cold vs warm starting, you'll always need the choke on to start 'em regardless of what the manual claims that's just how it is.
5 - theres a throttle travel limiting screw that's adjustable on most mini bikes, Coleman decided to tack weld them in place.
Cut it off with a dremel and you'll go from 18mph to between 21mph and 23mph.
I'm sure the free speedometer app I download is probably not the most accurate, but one of my bikes settles in at a top speed of 21mph while the other settles in at 23mph after this quick " modification ".
Overall I'm very satisfied, they start on the first pull every time and are a ton of fun.
