- Jun 3, 2019
What happened???View attachment 1180673
Eight stitches, fractured finger and torn out fingernail in the blink of the eye. Be careful out there folks!
Ouch!!! Buffer mishap? Grinder pinch? Overly aggressive hamster?Eight stitches, fractured finger and torn out fingernail in the blink of the eye. Be careful out there folks!
You kinda are obligated to tell the story. This is a request if that's what you are waiting on.View attachment 1180673
See post #9122 above. Not much else I can add other than, "dang, that happened fast!".You kinda are obligated to tell the story. This is a request if that's what you are waiting on.
Are rest tool on your disk sander grinded like chisel from bottom side where I draw that red line ?New user of disc sanders, too much gap between table and disc. Glad it was a wood scale and not a piece of steel!
Yes, it is as you have drawn. I simply did not have the rest close enough to the disk and when the scale's thickness matched the gap, it bit me. lesson learned for sure!
Can you imagine this ? I have a friend who has some automatic machines / I don t know name of that things / which can make large series of small steel parts from max. 16mm Dia steel rods ...say tings like pivot for folder knife .Once you make set up they will make thousands .....he give to me lot of different size rods from 304 stainless , most are left over long about 4 inch .... how in the name of God I pick up wrong one ????? I check all of them and all rods are stainless , except this one ?? And I used that one as pin which is some carbon tool steel for bolster on this knife ???? Lucky me Now what ? Pin was pinned , have lot of notch ...hole for pin in bolster is heavily tapered and glued .............
When I glue scale I use long pins , when the epoxy dries I use hammer and they go out .Then I shape handle as I want , make some taper in hole on scale where pins go and then I pinned them ......
Little more sanding on handle and I was done ......with rusty pin !
PS . Carbon scale are made with phenolic resin...when wet they are like Micarta ...not like plastic . I like them !
Working on a 40th birthday gift for my hunting buddy. A skinner in .14" RWL-34. Blade is a around 5 1/4". Brass guard and redwood burl scales to be fitted later on..Sanded to 400 grit so far, and I might just stop there. The blade is actually the first one I ever ground, so kind of fun to give.
