- Apr 22, 2011
I agree, great marketing.
I have a question about the blade.
In this photo
It looks to me as if the thickness at the edge is very thick and that the secondary bevel is too large and obtuse
How are the thicknesses& angles and how does it cut ?
and
Can you tell me how are you finishing the thumbstud?
Bevel or deburr the corner to kill that sharp edge.
Undercutting the slabs and the lockbar to help get a thumb under it ?
That is a massive secondary bevel.
Edit: Looks like we were posting at the same time count.
thumbstud looks a little sharp on the top edge as well
Well I've gotta say. That is some incredible work and incredible marketing you are doing. Good job!
The possibility of galling should be non-existent on a stop pin.The thumb-stud has been finished with a tungsten carbide coating to mate with the carbide coating on the engagement surfaces of the slabs. Remember this isn't just the thumb-stud its the stop pin as well. In order to keep the thumbstud from galling the slabs overtime I carbidized all the surfaces to 71RC to keep lock geometry stable and solid. Yes Mike its kinda sharp but frankly it is first an foremost a flipper and not a stud deploy system. Now that I feel it in my hand I think I'll just break that edge to keep any burrs from catching.
Galling requires pressure, AND movement.
You can press two things together forever, and never get any galling.
You may get plastic deformation, but they won't gall.
You have to have sliding motion, along with pressure, and a stop pin should never have that.
In other words, there should never be any relative motion between the contact point on the pin and the contact point on the frame, and motion is required for galling.
I'm not trying to talk you out of it, if it's your thing.
But, carbidizing won't stop plastic deformation either.
It's too thin to do that.
All it does is add a hard layer to the surface, but does nothing to the substrate.
It's like a putting a silk pillowcase on a burlap pillow, the surface of the pillow is changed, but when you push on it, it's still a pillow.
Can you post a video of the prototype in action. It would be good to see the flipping action and maybe a size comparison to another knife to get an idea of the Titans size. Knife looks great.
what software did you use to make that video?
Adding Ti to an existing knife can take some slop out if it is there, because you do actually change the dimension if the carbidized part.
If you have a loose lock, sometimes carbidizing the lock face, and/or the stop pin will tighten things up, because you added material, and slightly changed the geometry.
Plastic deformation of the stop pin interface is where a lot of knives run into trouble, ending up with locks that over travel.
A lot of guys have the stop pin hit on a flat, or convex surface, effectively meaning just a tangent point of the stop pin comes in contact.
It's easy to deform that, and it happens a lot.
Now the blade opens a fraction of a degree further, and the lock travels further across the tang.
From your pictures, you seem to have done the right thing, by having your stop pin hit in a concave surface.
Effectively meaning you won't have a POINT of contact, but a PATCH of contact around the circumference of your stop pin.
It doesn't take much, just a few degrees of arc, but it makes a huge difference on longevity.
can you post a video showing the basic opening and closing? i'm curious to see just how smooth this beast is to open and close.
