Mine does the same, but the stop is not flat so it wobbles back and fourth. It’s just odd to me, I haven’t seen it before.J jsdistin - Interesting observations on the BRR. I’ve oiled and flushed mine and some of the “mush” in action has been significantly reduced. My BRR definitely has a half stop action. As I open the comb it snaps into the 1/2 open position. Additional pressure snaps into the full open. Same action while closing. (Snap may be an exaggerated description, but there is a very discernible spring and stop during the open and close process). So my question to those far more knowledgeable than me - what’s it called when a blade/tool has a cam but action is consistent with a half stop?
Vid of BRR action.
Vid of BRR action.
Pull on the BRR is much lighter than the pull on the main blade and fork/opener.
You’re action is way, way better than mine.
Did you flush yours out? I didn’t get to that yet. Actually I may not as this one may go to a buddy.
I sure hope the M&G 35's have a stiffer pull.
To me the etch on the M&G make it more of a "novelty"Relax, I think that's certain, it's a single-end two blade Jack knife. Not a 'novelty'
The S&M Heritage series premium stockman has those type of half stops. Kind of a casual half stop if you will.Mine does the same, but the stop is not flat so it wobbles back and fourth. It’s just odd to me, I haven’t seen it before.
It sounds like an eccentric cam. It can be shaped to almost be square.
A quarter stop?It's a half stop, half stop.
A lot nicer than expected.
The comb/strainer is really thin and could easily be looked over as it so flush against the side.
Good overall size.
Blades have nice walk and talk- a bit lite but not bad. Strainer is very lite but since it’s not a main blade it doesn’t bother me.
Now some compression pics with its older, better looking cousin
