Another suggestion,Concern regarding lack of material at finger ring area.Due to hard abuse that may be a wink link.Making last minute design decisions.Finger ring not neccesary.IMO.Also add mass where you would want it,The head.
Keith,It serves as a area the kydex is molded in the hole slightly to index the head to the sheath.Sorta detent.
Simplifiying the sheath without spine & carry box.Now sheathing attachment,I'll have a universal cavity molded in kydex the area of the attachment.I think.The design has come to this configuration.I like the spine idea,I'll make a proto to test anyway
To further simplify the sheath,I opted to remove strapping fixture.
A suggestion was made concerning the comfort of the traction notches on handle,Traction notches on scales only.
Moved hole for head sheath detent.
Moved oxygen wrench slot down slightly.
I am liking the simplifications. Maybe you could have one scale longer than the other so that you can hold it nicely further down and still be able to pry?
Ok,lengthened handle.
Moved holes & slot.added 1 more hole.
Moved handle serrations.
Beefed up neck area.
Tweaked on the seat belt cutter.
I see the end coming near!Now you can see what goes into the CAD design process,But well worth the work.
Added 2 locations for possible TekLok at front of head sheath.Chicago screws 1" on center.
Vertical & horizonal oxygen wrench slots on end near pry bar.
Profiled the wire breaker similar to a skeleton key hole.
Waiting on a Molle vest,Get a look at making rig Molle compatible.
Frank,I think a nylon strap with snap should be secure enough.I'm researching strapping materials.Soon as I get my hands on that molle vest,I can make it compatible.Checked with Crucible on S-7,I'm still not sure if I should go up to 3/8"(.375) thick.1/4" or 3/8"?Would 3/8" material be overkill & add unneccesary weight?
