- Mar 20, 2016
Just remember that Leprechaun is pronounced something akin to Leprekahn. I'm just saying
I took off Friday for a long motorcycle ride
I do appreciate it.
...I suspect the word "coil" to be, in it's earlier forms, the initial derivative. Webster attributes first use to 1567, though made famous in Shakespeare's "Hamlet" in 1602. If you've seen some royal cutlery or knives from the 16th and 17th centuries, some would have elaborate, delicate metalwork at the area we refer to as the choil. Imagine a choil that is simple and rounded, then add an inch of scrolled metal (part of the actual blade) heading around or within the choil area, or pointing downward, with circular twist/flat plain, eminating from the blade edge at the front of the choil. The patterns of that little piece of metal were often semi-circular. The definition of coil - "to wind into rings or spirals". Could be that for lack of a better word, blacksmiths started calling this area the coil, later changed to choil, perhaps, but retaining the same pronunciation. It certainly wouldn't have been a common usage word. But with diction(ary) evolution, pronunciation changed, unsilencing the h.
You know, it kinda adds up when you think about it. But the last thing I am is an etymologist...
Looking good! Any chance it'll have a swedge?
I doubt it very highly because SK is abbreviated for Survival Knife so having a swedge may not lend itself too well to its ability to be very safe under heavy batoning in a possible survival situation! It would look cool though!
there will be a fuller if the material is thick enough for that to make sense.
