I concur.I'd kick that up a step further. From personal experience, even most SF guys aren't knife nuts. At least they weren't back in the early 90's when I was assigned to 3rd Group and later 10th Group. The knife I remember seeing most frequently was the basic original Leatherman. There were also a lot of Gerbers (that's what the PX sold, mostly).
Outside of our community of knife-obsessed wackos, knives are just basic work tools to people whose work requires cutting things.
I concur.
Most sf type guys I know in and out of service, including those met in Astan, had/have scant interest in knives or guns outside of training/missions.
A whole lot of them only wanted to and talked about parachuting.
I like jumping out of perfectly good airplanes as much as the next guy but its hardly as interesting as knives![]()
Thanks.Correct...it’s been over a year now that models no longer have the date
I loved it though I jumped in my spare time with military buddies when we were all in the service (i.e. I was never paid to jump).Jeebus I didn't! I was very happy when my orders got changed from Bragg to Drum
Not so much BEFORE the first jump though
From the plane, cows n people n cars suddenly looked VERY small on the ground.
Don't bother buying an Emerson.
Emersons are poor contenders in every category. A RAT 2 in D2 will do a better job and be more secure than any Emerson ever made. A Spyderco Military will slice better, last longer, and won't come apart if you abuse it.
I'm sure he didn't mean literally, or at least I hope he didn't. The edge grind on those knives are probably the most stout thing about an emerson, for better or for worse.Where do you get the idea that Emerson knives come apart if you use them?
Sounds like you have opinions based on not using the knives...
I have 3 Spyderco Military's, and 5 Emerson knives. None of those knives have fallen apart.
I can tell you that the tip on the Military will bust off before the one on the Super Commander, if that's your definition of abuse.
Hey, look at this Emerson knife fall apart!
I don't know where people seem to get this idea that an Emerson is somehow indestructible and their liner lock is immune to damage. There's no reason that you should have to adjust your blade in the field because it's poorly made (A well-made knife should not have to be adjust in the field because of somebody's ego), and there's also no reason for it to have a soft poor performing steel that's going to need constant maintenance. Want a hard use knife? Get something with better materials for less. Cold Steel has knives in S35VN now and will outlast any Emerson. Spyderco and any other knife manufacturer have plenty of options that will be better suited for abuse.
While mine didn't fall apart, it certainly gave me the impression that it would, being easily one of the worst constructed knives I've ever taken apart. It literally creaked when I squeezed it tightly.
My Emerson Micro commander will creak a little bit if the screws are loose, particularly the pivot.
That said while the fit and finish is not amazing on Emersons, (it is improving lately) that in no way means they are poorly built or likely to fall apart.
In fact my Emersons are extremely well made. They are one of the few knives I can take apart again and again and they go back together with zero issue. Most other knives seem to be less capable of this.
Which model years are your knives? Mine was a 2012 Roadhouse. Maybe (hopefully) they've gotten better since. It creaked with everything tightened down just from pressure on the thumb ramp. I don't think the screws were loose, because that was already with a stiff pivot setup to keep the blade from wobbling and from opening up unintentionally.
IDK, my Emerson was more difficult to get back together than most other comparable liner/frame lock knives, and I was a bit concerned about stripping the hardware. For ease of maintenance, I prefer my ZT 0620.
