Tizwin, the rationale was to get the blade directly in line with the radius bone of the forearm when the average human wrist was in the "locked" position, which puts the middle knuckle of the hand directly in line with the axis of the forearm.
This is what gives the C60 its superior stabbing accuracy that posters in this thread have mentioned, and it also gives
tremendously more penetration, because it aligns the skeleto-muscular support structure of the arm with the point (number one), and therefore with anyone who knows how to put his weight behind a punch, gets the entire body's force going directly behind the point (number two).
As other posters have also noted, the handle-to-blade angle puts much more force behind a slash as well as a stab. Instead of the blade "skimming" over the target as it hits hard resistance such as bone, the 90 degree angle of the blade when held in reverse grip (and KEPT there by a handle shape that allows the thumb to lock it at that angle) the C60 is more likely to shear directly through whatever resistance it encounters. Because of the design features, something very similar happens with a slash from the conventional saber or pekal grasp.
As to the tip-down carry: I'm one of those early Spyderco fans whom Sal calls "Clipiteers," [
] who started their Spyderco experience with the original Police model, learned to open it with a pinch-snap, and discovered we could win bets beating guys with bali-songs and even "automatic knives" in opening speed. The pinch snap uses the gross motor movement of the closed hand instead of the more fine-motor skill of using the thumb to open the blade via the original design intent of the "Spyder-hole."
As has also been noted (you guys n' gals are sharp, no pun intended) the C60 had ambi holes drilled so the clip could be moved for southpaws. I did not consider tip-up carry in the design parameters, and would have to go back and play with the concept a lot more to see how well it would work in that fashion. I realize that a lot of folks are as habituated to tip-up carry as I am to tip-down.
And needless to say, I'll give a +1 to the sprint run suggestion...
