sharp_edge
- Jul 30, 2015
Exactly this. The 0462 has milling on the titanium lock side and precision milling/chamfering on the CF side. It has milled pockets to lighten the weight on the titanium side. It has a hardened steel insert. It runs on industry standard bearings, which allows for user swap to ceramic if they choose and the bearings are still arguably better than the new proprietary bearing setup that Spyderco adopted post-Advocate. If you go to a couple of websites and input a coupon code, you can get it for around 220 USD like I did. You explain to me how you go from that to the price of the Drunken with the addition of a bit more milling, a nested liner, and some proprietary bearings?
You can't compare this to Olamic, Reate, and other mid-tech makers to explain the price. The quality level and customer service from those companies are much higher than Spyderco for the most part. They also produce far fewer numbers than Spyderco and still manage to stay in that price range.
The simple fact is that this knife, regardless of it's quality is priced well outside of the range it should be at. I predict a similar situation to certain other models that were a little less overpriced (Slycz Bowie, Southard, Positron, and Nirvana). The sales will be lackluster and the knife will be discontinued, leading to deep discounts. I'll just wait till then to pick one up, thanks.
Where do you get that ZT 0462 has milling on the cf scale and ti side? If anything, the milled and contoured cf scale and lock side of Drunken are MUCH better and MUCH refined than ZT 0462.
And how is the quality level of Reate's custom service much higher than Spyderco? (I am not knocking Reate)
I am not saying that the price of Drunken is great but some of what you said is just not true.
