Traditional slipjoints have the kick resting on the backspring. These seem to have a stop pin, which is a more modern design, I believe.I also noticed I can’t squeeze the blade further into the well after it’s closed. It’s the first knife I’ve ever noticed that on.
{ Your item was delivered at 10:01 am on November 16, 2020 in POINT ROBERTS, WA 98281.
USPS Premium Tracking™ Available
Delivered
November 16, 2020 at 10:01 am
Delivered
POINT ROBERTS, WA 98281 }
So, the knives for Canadian members arrived today in WA!!
Now I have to go across the border and get them! Hopefully I/we won't get hit for duty charges!!
Then I have to self quarantine for 14 days, during which I will package the knives, and hopefully get a reliable person to post them before 14 days, after which I will post them myself if I have no luck!!
They sure look worth the wait!!
Sorry there will be a bit of delay!! I will post progress as it occurs!!
I can see that as a disadvantage, if one were to sharpen the blade to the extent that the tip becomes exposed above the frame. When fixing up vintage knives, I can file down the kick to drop the blade deeper into the well. I suppose with this M390 steel, it should take quite a while before it becomes a problem.
Something that impresses me the most is the attention to detail that these knives exhibit. I love how the swedge of the blade seamlessly fades into a rounded contour to meet the backspring.
I think so too. I think Viper will be getting more business from BF members in the future. I really never considered one of their slip joints.Something that impresses me the most is the attention to detail that these knives exhibit. I love how the swedge of the blade seamlessly fades into a rounded contour to meet the backspring.
I think you're right. I may be mistaken but the stop pin appears to contact the crescent shaped cut out at the base of the tang. To file that part down you would have to disassemble the knife to prevent inevitable damage to the bolsters.Traditional slipjoints have the kick resting on the backspring. These seem to have a stop pin, which is a more modern design, I believe.
Not much of a concern as these are designed for disassembly. Just an extra step in the process.
Good point. I didn't think about these being take-apartable. No worries, then.I think you're right. I may be mistaken but the stop pin appears to contact the crescent shaped cut out at the base of the tang. To file that part down you would have to disassemble the knife to prevent inevitable damage to the bolsters.
Delivered
Delivered
I've had the Swayback in Stag for the better part of this year - I cannot recall if I've ever put it to the stones. This steel has pretty excellent retention and where I am stropping my GEC carries every few days (depending on frequency of carry and use), I haven't had to do so with the Viper.
Granted, I may not use my knives as heavily as some here might.
I get your point regarding the stop pin though. It makes things a bit tricky should the tip ever get exposed.
There is a stop pin in the well, if you look at the tang you can see a round cutout that will rest on the stop pin which makes it impossible for the blade to rap the spring when snapping shut. These also have mill relieved liners. Such a well built knife for the price!I can’t get over the rounded back spring, and how it wraps around the bolster almost touching the blade again. Really well done. I also noticed I can’t squeeze the blade further into the well after it’s closed. It’s the first knife I’ve ever noticed that on.
I’m not one to fidgit with knives, but I like when a closed knife doesn’t have sharp edges and just feel good. Horn has such a warm feeling. All that and a wharncliffe what a great knife.
Just a great knife. Definitely going to get some pocket time
