I'm scared of bugs, so my new handle has been sprayed with kerosene and rubbed with kerosene and linseed oil. It seems fine with it.![]()
Yes and a outstanding one !Mine came earlier than expected, this past Monday (after the USPS tracker predicted today, Wednesday). Unfortunately I had already left home to hunt for a few days, and just got to open it up and look today. What a great surprise - I got the Rachel model - looks a bit like the Hatteras Lighthouse. Great walk & talk, great fit & finish, very sharp, and cool to boot! OH
Ps I take it the tang etch of "M390" is the blade steel? Is that a stainless steel? thanks to Mike at Collector Knives for making this Blade Forum Knife happen!
That, and I found 2 cans in the cupboard I forgot about till now.Well gosh, y'all can buy SPAM anywhere. I'd send some Texas pecan pralines!![]()
Just strop it once in a while and you’ll probably never need to sharpen it unless your really hard on it.
M390 is a super steel manufactured by Bohler-Uddeholm (result of merger of Austrian Bohler and Swedish Uddeholm). It uses third generation powder metal technology and developed for knife blades requiring excellent corrosion resistance and very high hardness for excellent wear resistance.
Your very welcome SirThat is splendid! Thanks for the informative answer. OH
I know the feelingNoooooooooo! Mine is going to be late! Okay, it isn't really that big of a deal, but I was hoping it would show up today. It hasn't arrived at my PO yet per tracking info. I'll just have to scroll back and look at all the awesome ones that have found their way to their homes and wait for mine to show up, hopefully before this weekend. I know it will be worth the wait.
Quoting myself for a quick followup on this one....One side of the frame just lifts right off and the stop pin can be removed simply.
Takes just a few minutes.
I'm not sure if there are any variations in the grinds or f&f on these but if there are the results may vary regarding blade clearance.
One of those ymmv situations....
Earlier when I tested and measured with no stop pin there was plenty of clearance but I didn't check for clearance issues with a full snap back into the blade pocket.
So...I pulled it apart (just one side, only took a minute) and removed the stop pin then completely reassembled.
The tip just barely makes contact with a full snap with the pin removed, no contact in the center.
The backspring must flex just a little more than I thought it would.
Just wanted to follow up with accurate info.
And the tip "damage" was so slight I could hardly see it, just barely touched, took like a minute to put it back.
OK, now I'm done fiddling, just can't help myself lol.![]()
No contact with the stop pin installed, just touched with it out, and that was only when the blade was allowed a full snap back into the frame.If it is finally sharpened down to a point that it needs dropped; the stop pin might be the only solution required. Since you already lowered yours it may have allowed the impact. Just a thought.
I appreciate the offer. I'll think about it, but I don't imagine much can be done to fix it.Horn can be bent under heat. If he wants to send it back I can attempt to fix it. I have no replacements and the factory has no more (nor will it probably ever be made again).
OO. Sounds more impressive than I realized. I haven't actually cut anything with mine yet, never mind sharpening it.Yes and a outstanding one !
M390 is one of if not my favorite blade steels.OO. Sounds more impressive than I realized. I haven't actually cut anything with mine yet, never mind sharpening it.
