Well got it... Box dated June 2018.
Seems the handle is a little better seemingly a bit bigger and tweaked contouring, and its grippier when wet so Athletic Tape might not be needed. Seems OKC listened to our handle "observations", now to see if I can swap these handles to my 5160 one...
The Fit and polish on the non blade part (Choil area) I don't see as well buffed or wuffed, but this is 420 HC and I guess they that much buff and polish every where was to try and keep corrosion down. Me I don't mind the finish not being so Buffed and Polished and so Shiny I can do my make up in...er image enhancing regiment products! I mean to use the blade not put it under glass like a pheasant to get looked at by looky lookers awaiting to be liberated by a real user!.
The spine isn't as literal sharp as another set of knives sharp like the 5160 version. But they seem to be good enough to throw a spark I think. You can see the water cut marks that make it look and feel "rough" if you press your hand down on it, it goes like that through the whole tang and stuff. Some slight nicks in the edges but I think that would be from the production process of steel being moved around. As stated before "I think" the 5160 needed the extra polish and burnish to help try and keep rust and corrosion down. The very end of the tippy end seems not perfectly even, that would drive some "I NEED IT PERFECT! AT100%!" anal retentive types to be set off, but OKC Hand Grinds their blades so there might be some ever so offish ones. For me I can live with that as its not a $1234.56 dollar knife where I would expect it to be. Being 420 SS the knife is more corrosion resistant than 5160 so I can accept the water cut marks. As the same type of water marks can be seen under the coatings of my other big okc blades. For a great AFFORDABLE quality knives the OKC does, I can live with a few "BAD COSMETIC" looks.
Now then as for the steel, I haven't seen if its 420 HC or what other version it might be. So for now I'll use it like my CS Marauder in AUS 8A I use for water based trips and do light to medium duty stuff with it and yes Kitchen stuff...if my little sister don't get away with stealing it...
Does any one know what form of 420 it is? I've got Gerber Strongarms in 420 HC I've done horrific things with they still hold true to form. (Yes, several needed resharpening after what I did...but I use them for the literal beater blades.) For the harder things out comes the TFI or another RD line blade.
