Rose and Thistle Custom
Josh Mead
- May 9, 2018
I chucked pin in my drillpress and held a file against it.
I got that part but in a previous post he mentioned acquiring drill bits in various sizes...just wasn't sure the context exactly since we were talking about modifying pins.I thought what he meant was put the pin stock in the drill and file it down with a file while the drill is spinning.
I do have a drill press and will definitely try that next timeI chucked pin in my drillpress and held a file against it.
I started to answer this and got about 5 paragraphs in and erased it because I was rambling terribly. The drill bits are for drilling the pin holes after gluing and placing the covers if they aren’t very close to the right size you’re either drilling the hole too small or too big. Too small and the pin is held by whatever the cover material is which if there is any shearing force may crack the covers. Too big and it has to be peined more and there is the possibility of side to side movement or you have to drill the spring to match which may work but in my opinion it’s not worth the trouble (other opinions may vary) basically for me right now the challenge has been in getting the right drill bit for the size of the hole in the spring pin. I don’t think the other pins matter as much, like the ones that hold the covers on or the back pin. I’ll stop before I start rambling again.Ahhhhh...that seems like the way to do it.
You mentioned the drill bits of various sizes...are you suggesting to use drill bits for pin stock? Or just saying there are bits the same size as various pin stock (insinuating that existing holes would indeed need to be drilled out). Sorry a little confused by that.
Ideally, Id like to have all the various sized pin stock....seems easy for brass but not so much the nickel silver.
Got it thank you You are saying it is best to have a good variety of bits that properly fit the existing holes and then grind down a pin to size...which makes perfect sense. I have been using a 1/16", 5/64" and 3/32" bit primarily...which correspond to my pin stock sizes.I started to answer this and got about 5 paragraphs in and erased it because I was rambling terribly. The drill bits are for drilling the pin holes after gluing and placing the covers if they aren’t very close to the right size you’re either drilling the hole too small or too big. Too small and the pin is held by whatever the cover material is which if there is any shearing force may crack the covers. Too big and it has to be peined more and there is the possibility of side to side movement or you have to drill the spring to match which may work but in my opinion it’s not worth the trouble (other opinions may vary) basically for me right now the challenge has been in getting the right drill bit for the size of the hole in the spring pin. I don’t think the other pins matter as much, like the ones that hold the covers on or the back pin. I’ll stop before I start rambling again.
That’s pretty much what I’m talking about except with a hand drillI chucked pin in my drillpress and held a file against it.
I’ve seen the decimal pin stock which corresponds to a fraction but I haven’t seen these drill bit sizes, but I haven’t found any pins that are the proper size for the pre-existing holes in at lease GEC, Dwight Devine or a case knife, what’s worse is that the different holes seem to be drilled to different sizes. I’ll check into those bits thanksKnife shop machinists usual refer to pin sizes in decimal, and drill bits in decimal or corresponding size number. A common center pin and bolster pin size is .086", which would be drilled with a number 44 drill. Another common pin size is .093", with the drill being #41. A few useful tools would be a set of pin gauges, a drill/wire gauge, and a Vernier caliper. These help to take a lot of guesswork out of hole/pin sizes.
Eric
That certainly may be the case because I’ve have a few where a very small amount needed to be removed from the pin for it to fit.I have also had various issues with pins. I wonder if part of the problem is the tolerances in the manufacturing of the pin stock. Depending on where the pins come from, the diameter may not be super precise.
That’s exactly what I had started out doing and am just recently doing it the new way because of a few issues I’ve noticed, none catastrophic though.Got it thank you You are saying it is best to have a good variety of bits that properly fit the existing holes and then grind down a pin to size...which makes perfect sense. I have been using a 1/16", 5/64" and 3/32" bit primarily...which correspond to my pin stock sizes.
Thanks for the feedback!
Finally had time to work on things...and got this project done (the right way this time).
It still cost me a few more 1/32" router bits but it went a lot better this time. I stuck a .008" feeler in between the blade and liner when I peened the pivot pin and it worked great.
Next I need to work on getting the pivot pin to blend with the bolsters better...not easy to do!
Anyway, I really like how this turned out.
Great looking knife. I can’t believe you’ve only done a few so far. You’re progressing faster that I am, for sure.Finally had time to work on things...and got this project done (the right way this time).
I think you've found your calling... you're progressing rapidly.Finally had time to work on things...and got this project done (the right way this time).
amazing. great jobAnother RR project...this one in Pau Ferro.
